Fall off of power in LT1 -1992 z-28
Old Sep 22, 2011 | 10:49 AM
Lakelady's Avatar
My engine has slowly been losing power...I began with a tachometer reading of 2750rpm in fifth gear at 100mph; slowly (over six months)the engine has lost power and now in fifth gear 2750rpm only gets me to 80mph...
New clutch, drive train and rear axle all the same, advice? Camaro Z-28 1992 with LT1 engine
Advice?
Thanks!!!
Old Sep 22, 2011 | 11:49 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Fall off of power in LT1 -1992 z-28
5th gear? LT1? Are you sure you have an LT1? Are you using a 5 speed or a 6 speed?
Why are you going 100 mph?
The tachometers in these cars are notoriously innaccurate.
Fact is, when the clutch is engaged and the engine and transmission are locked into each other, everything is constant. Even if you're down on power, a certain RPM in a certain gear will ALWAYS mean you're going that speed. It may mean you have to push down the throttle more to get to it, but at that RPM, that speed is always the same. The engine and the road are mechanically linked. There's no way for the engine to be at higher RPM's and the car be at a lower speed. The only reaosn that can happen is the clutch is slipping or your tach is wrong.
I have done all the maths and I use my RPMs as a way to be able to tell how fast Im going in my car. At 2000 RPMs in 4th gear, I am going 45 mph. There's NOTHING that can change that, even if the engine were WAY down on power, except for a slipping clutch.
Old Sep 22, 2011 | 12:47 PM
torque_is_good's Avatar
Advice?
Thanks!!!
yup
why second guess yourself
go to a local shop with a dyno and pay for a few pulls
Oh, how does the waterpump get turned on your engine?
Old Sep 23, 2011 | 01:25 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Clutch slippage is the only possibility for what you've described.
Old Dec 21, 2012 | 10:47 AM
Lakelady's Avatar
Advice?
Thanks!!!
Well thank you all for your thoughts ..... what actually happened was my mechanic stole my LT-1 engine and replaced it with a pos 350. Now I need to replace the pos 350 with something like or another LT-1. Is there a more smog-friendly newer engine? Sooooo miiss the LT-1
Old Dec 21, 2012 | 10:56 AM
86LG4Bird's Avatar
Old Dec 21, 2012 | 11:01 AM
Lakelady's Avatar
Nice- is that you, Arlan Camara?
midge54
Dec 27, 2019 04:14 PM
louishenry
Aug 28, 2015 09:41 AM
sailtexas186548
Aug 24, 2015 10:11 PM
zayne0
Aug 24, 2015 07:22 PM
sreZ28
Aug 14, 2015 07:48 PM
