Fuel pump fitting
Car: '85 Z28
Fuel pump fitting
Hey guys,
Can I use this fitting on my stock mechanical fuel pump? Is it the correct size?
http://www.autozone.com/autozone/acc...equestid=35173
I need a fitting like this for the pump output to the carb.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Fuel pump fitting
IIRC the stock pump has an inverted flare fitting, not a NPT fitting. IDK what the right thread is though.
Car: '85 Z28
So would the fitting below be correct? I'm not close to the car so I can't try it out.
http://www.dormanproducts.com/mobile...3-785-408.aspx
Thanks!
Car: '85 Z28
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
