383 stroker???wrhp???wrtq??
Old Sep 25, 2011 | 11:30 PM
Fermin91rs305's Avatar
Car: 1992 Camaro B4C
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
I was wondering what type of power you would think I would be making with this 383 stroker setup...
383 stroker
Ross forged piston and rods
Cam 244/254 .510/.533 114lsa
Vortec 200cc and 58cc chamber
Holley stealth ram 58mm
36lb injector
255walbaro fuel system
custom tune
I have a 1992 camaro stock interior
700r4 pro built tranny strip/street
3200 vig stall
Moser 9" rear end 4.11 gears
Will be racing with drags 28".
Can you estimate wrhp and or 1/4 time in Las vegas weather?? Thanks
Old Sep 26, 2011 | 06:32 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: 383 stroker???wrhp???wrtq??
What's your CR? deck height? head gasket thickness?
If you did everything right, and your tuner gets his part right, 425 rwhp and high 11's in Vegas.
Old Dec 3, 2011 | 03:49 PM
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
i know my compression is 11:1 and zero deck height. And great thanks
Old Dec 3, 2011 | 04:58 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
you must be running a dished piston then. 0 deck with a flat top and 58cc even with a .043 gasket is gonna be over 11.5:1
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
