Stalling & Raw Fuel Smell?
Old Sep 26, 2011 | 09:30 AM
VEGASIROC's Avatar
Transmission: Manual
Hello Third Gen Friends,
I have a 1990 IROC (305/TPI/Manual Trans/194,000 miles). I drove the car around all morning running fine. The engine stalled right after start up after sitting for a couple hours. It took about 5 cranks and about 100 yards to get the car running.
It does throw out some white smoke after sitting for a while. (5-10) seconds
I recently replaced the 02 sensor (Delco) and the car passed smog.
I have the common code 32 error (EGR) every time I drive.
I can smell raw fuel coming from the exhaust.
Please help with any type of driveway diagnosis and parts replacement.
Thanks.
Old Sep 27, 2011 | 07:02 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: Stalling & Raw Fuel Smell?
if the white smoke from the tail pipe has a strong smell of gasoline, its raw fuel being vaporized in the exhaust.
look for leaking fuel injectors or fuel pressure regulator.
first thing to check is the fuel pressure regulator. it not uncommon for them to leak fuel into the intake.
any signs of liquid fuel in the vacuum hose is a sure sign its bad.
Old Sep 28, 2011 | 02:12 PM
VEGASIROC's Avatar
Thanks you for the advice.
jklein337
Sep 19, 2018 06:23 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
