Oil pressure switch
Old Sep 27, 2011 | 05:53 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Oil pressure switch
On a 92 Camaro with TPI, does anyone know at what pressure the oil pressure switch closes? The switch is normaly open under what pressure? I installed new autometer guages so I have to use there sender. So beacuase of space issuses I want to get a unversal oil pressure swicth but I need to know what pressure one to get. I have a one now that is normally open below 9 psi and I'm not sure if that would be ok.
Old Sep 27, 2011 | 06:23 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Oil pressure switch
I don't know the exact value, but it's pretty low. Considering that the switch doesn't even do anything 99.995% of the time, 9 psi should be fine.
Old Sep 27, 2011 | 07:18 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
ok thanks
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
TA8487
Aug 16, 2015 12:21 PM
