Bleeding brakes
Old Sep 29, 2011 | 06:21 PM
88blueiroc's Avatar
Bleeding brakes
Trying to bleed the brakes on my 88 Iroc, new calipers in front, rebuilt calipers in the rear, the front bled fine, can't get anything out of the back. the pedal was hard after bleeding the front, acting like the system was fine. I checked the line to the back for clogging by air pressure and it was ok. what am I missing? Thanks.
Old Sep 29, 2011 | 06:24 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Bleeding brakes
when bleeding the whole system you want to start with the caliper furthest from the booster, ei, the rear passenger side. then the rear driver side, then front passanger side, then front driver side.
83 Crossfire TA
Jan 3, 2016 01:26 PM
dbrochard
Sep 19, 2015 08:13 PM
dimented24x7
Sep 6, 2015 03:51 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
