A/C Cycling On/Off every second
Old Sep 29, 2011 | 07:58 PM
2nd Try's Avatar
No matter what position I put the HVAC control to have the A/C on the condenser itself is cycling on/off constantly, about once every second. I know this isn't normal. This is a 92Z w/ 17k original miles I picked up last month. My previous 91Z would just stay on, like all cars. Previous owner knew nothing about the car...
Any ideas where to start? Just needs a new compressor or is this simply an electrical issue and/or sensor???
Old Sep 29, 2011 | 08:34 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: A/C Cycling On/Off every second
ac clutch cycling is an indicator of low freon
Old Sep 30, 2011 | 12:35 AM
blackbeauty89's Avatar
Car: 1989 Pontiac GTA/2007 TrailblazerSS
Engine: 350 L98/LS2
Transmission: 700-R4/4L70E
Axle/Gears: 3.27/4.10
get the a/c recharged. but make sure to check for leaks first with leak detector.
Old Sep 30, 2011 | 07:38 AM
2nd Try's Avatar
Now that's the answer I was looking for! This is what I was hoping, but didn't want to do this until I had some expert advice. Will check for leaks first, then charge if all is OK.
Old Jun 7, 2012 | 10:08 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
How often should the compressor cycle? I just got mine going and it seems like my clutch stays engaged for a long time. It kicks off when I turn the ac off, and the clutch disengages while I give it gas then kicks back on. Is this normal?
Old Jun 7, 2012 | 07:31 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Minimum on time should be around 7 seconds. Any less than that and it's usually an indication of low freon.
Staying on for a long time is normal as long as the system is working properly. All depends on the pressures and if the evaporator freezes up or not.
jrdturbo
Mar 31, 2016 02:58 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
