parts question
Old Sep 30, 2011 | 05:45 PM
majormetallica's Avatar
parts question
doe anybody know where i can get a full list of every single part inmy camaro 1985 coupe? also im starting to gether oarts for a restoration i dont have alot of money so im buying it a bit at a time. i wont be doing the resto for a few years but what parts can i store for years an dbe fine and what ones cant i?
Old Sep 30, 2011 | 11:28 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Re: parts question
Welcome aboard! For next time, you should post in a more appropriate room (interior) in order to maximize responses.
A list isn't really necessary as you should be able to eyeball your interior yourself. Are you referring to the actual names of the parts? That would be understandable as a new owner of wouldn't expect the rear speaker covers to be called something like 'sail panels'.
If money is tight, I would do this; get inside your car and take a good long look at anything visibly broken or something that looks like it should be replaced. Write down the items or better yet, use a digital camera. Then, take a trip to a 'pick and pull salvage yard' to look for the parts you wrote down and/or took photos of. If the camera is with you, you can view the photos of what you need on the screen.
From lots of experience, I can tell you that your salvage yard trip needs at least the following:
  • A ratchet w/extensions
  • Sockets (both deep and shallow if you have them)
  • Torx bit sets (both small and a size 47-if you plan on pulling seatbelts
  • Phillips screwdrivers (small and large sizes)
  • Flat head screwdrivers (small and large sizes)
  • Wire cutters (should you need harnesses etc.)
  • A can of PB Blaster or other pentrant (mostly for seatbelt removal)
  • A flashlight (not often used, but you'll be happy you have it if needed)
  • Ziplock sandwich bags to hold hardware & screws and make sure you label the bag with a Sharpie in case you don't around to installing the parts for a while
  • A backpack (to hold your tools)
  • A large duffel bag (to carry whatever you choose to buy back to the office)
Good luck!
Old Oct 1, 2011 | 12:03 AM
all4u's Avatar
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
Re: parts question
I would try hawksthirdgenparts.com and classic industries first. To the OP, I got what you were trying to say.
redmaroz
Aug 16, 2015 11:40 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
reiderz iroc
Aug 13, 2015 04:57 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
