injectors!
Old Oct 1, 2011 | 03:06 PM
joecool1979's Avatar
Car: 1989 Chevy Camaro
Engine: 2.8L V6
Transmission: 89 GMC Jimmy Part Camaro Part Jimmy
Axle/Gears: Duno at this time
injectors!
anybody got a firing order diagram, and the injector order diagram?
I think my timing may stil be off but im thinkn it may be the injector order also..
Old Oct 1, 2011 | 03:22 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: injectors!
With the exception of the '89 TTA all 3rd gens with port injection are batch fire. The injectors all fire at the same time.
RBob.
Old Oct 1, 2011 | 04:24 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: injectors!
i always thought they fired left and right seperatly....
but firing order should be 18436572 with a counterclockwise rotation.
Old Oct 1, 2011 | 06:30 PM
Engine: 2.8L V6
Re: injectors!
It's the 2.8l V6 Bro
Old Oct 1, 2011 | 08:23 PM
travis401's Avatar
Car: 91 Camaro RS
Re: injectors!
It should be 1 2 3 4 5 6 starting from the front passenger side wire which is cylinder #1
Old Oct 1, 2011 | 08:24 PM
travis401's Avatar
Car: 91 Camaro RS
Re: injectors!
it helps if you actually list the basic info in your profile
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
