Testing Wires to starter
Old Oct 1, 2011 | 03:23 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
IM about 99.99% sure the solenoid is bad on my starter is out, it dont even click some of the time, but yet its pulling amps like its trying to do something, anyway i just wanna make sure it is the starter and not the car wiring
anyway, the big hot wire to the solenoid is always hot, and then the little wire to the little lug on the side of the solenoid sould power up when you move the key to start correct??
vatts is ok as the light does not flash, and it comes on like normal for a few seconds
Old Oct 1, 2011 | 04:22 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Testing Wires to starter
the starter should have a big post on the main body, thats where the battery and the main power wires go. then it should have a smaller post on the solenoid that has 1 purple wire going to it. the purple wire only gets power when you turn the key.
Old Oct 1, 2011 | 04:36 PM
89RS_82Z's Avatar
yep thats what i thought, just wanted someone else to say it
Old Oct 1, 2011 | 08:47 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If the purple wire doesn't get 12v+ when key turned, could be any number of things: http://www.austinthirdgen.org/index.php?pid=38
BRoss99
Aug 10, 2025 05:08 PM
Street Lethal
Apr 30, 2019 12:14 PM
Accerrito22
Aug 23, 2015 07:22 PM
milk
Aug 10, 2015 06:26 PM
L98GTA87
Aug 5, 2015 11:02 PM
