Modded l98 timing help
Old Oct 2, 2011 | 11:53 AM
jak's Avatar
jak
Ok story is i put a new l98 long block in the car with vortec heads..A very mild cam , 24lb injectors and a holley stealth ram intake and 52mm throttle body..Any suggestions on base timing .Seems to have a stumble at like 2k rpm..I wanna make sure my timing is dialed in before i chase anything else..Idle searches just a bit then levels out..As far as the chip is concerened i have an ED Wright custom chip burned for my setup.. Any help would be appreciated..
Old Oct 4, 2011 | 10:02 AM
JekyllandHyde's Avatar
Car: 87 Trans Am GTA
Re: Modded l98 timing help
If you're talking about setting base timing, set it to 6 degrees. 6 degrees is what matches your computer. Make sure you disconnect the EST wire on the passenger side (brown/black wire) before doing the timing adjustment. The timing curve is programmed into the computer itself.
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 19, 2015 10:07 PM
matthew911
Aug 12, 2015 09:38 AM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
