has anybody had this problem/s?
did the tune up about 11 months ago.(cap&rotor, wires,spark plug,fuel filter, ect.). car has been running real strong, everyday in the morning or whenever the engine is still cold , the car starts right up. but when its hot it will crank for like 3 secs then start. i assumed it was my something in my egr system since code 32 service engine light will go on on the freeway. so i figured out the egr solenoid had a missing piece. found it fixed it. service engine light does not come out on the freeway no more. but i dint realy notice any difference in the idle when i fixed it.( i assumed i was going to get a smoother idle) but the problem of hard starting persist. ive checked tps it passed the test. dint know how to test the connector that hooked up to tps.(so i dint check the conncetor) also the when i put the car in drive it bogs down but picks right up to leveld idle(but this is only sometimes NOT all the time). im not sure if its related since i assumed it was the egr solenoid since it opens and closes...has anybody have this problems? thx
Reaper Z28
Sep 23, 2013 08:26 PM
