A/C and Smog Delete. What to do with Serp belt?
Old Oct 6, 2011 | 10:13 PM
Impaqt's Avatar
Car: 88 Iroc-Z Convertible
So I just realized if I pull the AC Compressor and AIR pump on my 88 305TPI engine, I wont be able to lace a serpentine belt across my idler. THe are both on the passenger side with the Idler puller.....
Do I need to get a AC Delete pulley and/or smog pump delete pulley? Other options?
Old Oct 6, 2011 | 10:36 PM
lethaldomestics's Avatar
Re: A/C and Smog Delete. What to do with Serp belt?
a smaller belt maybe?
Old Oct 6, 2011 | 10:43 PM
Impaqt's Avatar
I suppose I could find a belt that would fit just Crank, WP, Alt, PS but if I do that, I would have no tensioner. THose are all Center to Driver side accessories. The Tensioner, Smog, and AC are all on the passenger side.
Old Oct 6, 2011 | 11:11 PM
Andrew James's Avatar
Car: 1990 Formula Firebird
Engine: 350 (5.7) TPI
Transmission: WC T5
Axle/Gears: 3.42 POSI
Adjuster for the alternator. A super short belt will also work.
Old Oct 6, 2011 | 11:13 PM
Transmission: WC T5
https://www.thirdgen.org/forums/engi...-question.html
Old Oct 6, 2011 | 11:30 PM
Impaqt's Avatar
Wow, those Delete pulleys have gone up quite a bit.....
I think I'll look into the adjustable alternator method. I'd really like to keep the engine bay as clean as possible.
jrdturbo
Mar 31, 2016 02:58 PM
jaridjohn
Oct 5, 2015 07:01 AM
