Serpintene belt question
Old Sep 28, 2011 | 08:33 AM
weesel72's Avatar
Car: 85 trans am
Engine: 5.0 carbed
Transmission: TH700R4
Axle/Gears: 9 bolt
I have a 91 305TBI that im converting to carb, my question is....i'm not using the a/c compressor, or the air pump. How do i " make up" for those not being there with with s-belt? Is it possible?
Old Sep 28, 2011 | 08:39 AM
Twin_Turbo's Avatar
Re: Serpintene belt question
or the air pump, rerout the belt (tech article here shows routing), for the AC you need an idler pulley, available from dorman and such (don't think the GM piece is available anymore)
Old Sep 28, 2011 | 09:51 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Is it possible?
https://www.thirdgen.org/forums/post...325-post1.html
http://www.summitracing.com/parts/NAL-10055890/
Old Sep 28, 2011 | 09:57 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Because some Vette owners are poor and can't afford the delete pulley ,
what we do is ditch everything ,
Install a std rotation SBC water pump and make a old style adjuster for the Alt
If you look at the F-Body belt diagram,the PS pump runs same rotation as crank
so in new setup belt runs Crank-PS -Alt -WP
Plus you get to remove any brackets and the idler on pass side to clean up engine bay
Might work for F-Bodies
( Appears Vette PS pump has opposite rotation so belt in F-Body would be under ; not over PS pulley)
Old Sep 28, 2011 | 01:40 PM
weesel72's Avatar
Car: 85 trans am
Engine: 5.0 carbed
Axle/Gears: 9 bolt
Thank alot for you help! Greatly appreciated!
Old Sep 28, 2011 | 01:42 PM
weesel72's Avatar
Car: 85 trans am
Engine: 5.0 carbed
Axle/Gears: 9 bolt
Good lord, horrible typing,lol! Thanks alot for your help! Greatly appreciated!
Old Sep 28, 2011 | 02:26 PM
Twin_Turbo's Avatar
nice wrinkle finish on those covers, very clean...yours???
Old Sep 30, 2011 | 08:08 AM
elesone's Avatar
When the water pump needs to be changed from reverse rotation (ccw) to normal rotation (cw), how can one tell by looking at the pumps what rotation they are? This is if one did not know the year or application and no pulleys attached.
Old Sep 30, 2011 | 09:28 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
As I noted in a similar thread; some of the Vette guys have run the rev rotation pump the opposite way with no bad effects.
The vanes on the impeller are apparently straight so they move coolant which ever way pump is turning.
Worth a try 1st to save some $$$
Old Oct 6, 2011 | 11:31 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Since i dont want to spend the money on the smog pump delete pulley, whats the right belt to get to bypass just the smog pump? I have a ac delete bracket/pulley already
Old Oct 7, 2011 | 12:59 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Get a piece of string , run it around the pulleys , get someone to move the idler in as far as it goes and measure length.
6 rib serp belts are generally listed by their length in mm
ie
6PK1550 where 1550 is the belt length
Old Oct 9, 2011 | 10:41 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
ie
thanks
1992 Trans Am
May 10, 2023 07:19 PM
mustangdmurder
Aug 21, 2015 07:17 PM
redmaroz
Aug 16, 2015 11:40 PM
jahblah
Aug 12, 2015 05:54 PM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
