shifter pops out of second gear need help
Old Oct 8, 2011 | 03:08 AM
88knightrider's Avatar
Car: 1988 Trans Am GTA
Engine: L98, 305, 5.0L
Transmission: Stock
When im driving and i shift securely into second, sometimes the shift will pop out of second gear into neutral so all i successfully do is rev the engine, how do i fix this? just a shift adjustment or what. Normally it wont happen if i shift quickly and very securely, but i cant shift smoothly or it will pop out. Anyone know whats going on?
Old Oct 8, 2011 | 07:33 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: shifter pops out of second gear need help
This is engine Dept
Trans Dept is on 5th floor
https://www.thirdgen.org/forums/tran...ns-drivetrain/
Old Oct 9, 2011 | 01:12 AM
Transmission: Stock
oh, unfortunately that doesnt help me, thoughts anyone?
Old Oct 9, 2011 | 10:10 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Yes, repost this on the transboard to get more responses, also letting us know what type of trans this is occuring in would help, aside from that I'll assume its a t-5, things to check would be the shifter itself for any wear but if this is only occuring in a single gear I'd suspect a bent shift fork, worn pads, but until you start taking it apart it's just logical guesses. Also another thing that comes to mind is one of the old hurst shifters that had the adjustable stops being misadjusted thus preventing proper engagement
Old Oct 9, 2011 | 10:31 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Originally Posted by vetteoz
This is engine Dept
Nice work!!
yes post in the trans section
GTAman
Jul 3, 2024 07:29 PM
IROCtometal
Sep 9, 2015 10:01 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
tonys91rs
Sep 2, 2015 07:07 PM
