Is this Third Gen Safely Jacked UP?
Old Oct 10, 2011 | 06:16 PM
oamhmad's Avatar
Car: 84 Trans AM
Engine: Goodwrench 350 Crate motor
Is this car safely jacked up? I've got in on 4 jack stands. The rear axle has to hang free as I'm going to remove the transmission.
I'm going to be under their for a while. Any way to make it safer?
It's about 18' in the air. Is that enough to slide the transmission out?
Attached Thumbnails Is this Third Gen Safely Jacked UP?-front.jpg   Is this Third Gen Safely Jacked UP?-rear.jpg   Is this Third Gen Safely Jacked UP?-left-front.jpg
Old Oct 10, 2011 | 06:17 PM
oamhmad's Avatar
Car: 84 Trans AM
Re: Is this Third Gen Safely Jacked UP?
Here are some more pictures
Attached Thumbnails Is this Third Gen Safely Jacked UP?-right-front.jpg   Is this Third Gen Safely Jacked UP?-left-rear.jpg   Is this Third Gen Safely Jacked UP?-right-rear.jpg
Old Oct 10, 2011 | 06:50 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Generally, I would say yes. But in some of the pics it looks like you have it supported by the soft part of the floor.
If you want to be sure, take 4 pics and post them. Use a trouble light for lighting, and get that camera as close to the ground as possible so you can take an upward angle of the contact point so we can give you a better answer as to whether it's safe.
And yes, 18" is high enough to get the tranny out.
Old Oct 10, 2011 | 09:03 PM
oamhmad's Avatar
Car: 84 Trans AM
Ok Thanks. I'll take some better pictures with a real camera and not a cell phone.
Old Oct 10, 2011 | 09:23 PM
89rs454's Avatar
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
Man that setup would hold that car forever lol, I'm still using cinder blocks and 2X6 pieces on gravel and dirt, there's a fine line between bravery and stupidity and just plain *****. cheers
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Thornburg
Aug 27, 2015 11:34 PM
