86 TPI....looks like oil in radiator and check out these spark plug pics please
Old Oct 11, 2011 | 06:54 AM
jb1's Avatar
jb1
I bought this 1986 IROC 305TPI/Auto a month ago from a member here, said it ran rough at start but after warmed up was fine. Anyway, trying to fix the cold start and due maintenance....I have found I have issues aside from the previous owner lying about the car.
Some members here receommended changing the CTS to stop the rough cold starts. During this change I thought while at it I might as well put a new radiator/hoses/thermostat etc. I removed the rad cap and see oil in the water.
I replaced everything, fired up the car and still runs like crap. It was late so I went to bed. Next evening after work I pulled the #1 spark plug and its wet with something....#3 plug same thing, switch to other side and #2 plug looks same.
Thoughts?....intake gasket?
Attached Thumbnails 86 TPI....looks like oil in radiator and check out these spark plug pics please-plug1.jpg   86 TPI....looks like oil in radiator and check out these spark plug pics please-plug3.jpg   86 TPI....looks like oil in radiator and check out these spark plug pics please-plug4.jpg
Old Oct 12, 2011 | 12:18 PM
91camarolover's Avatar
Car: 91 RS, 84 Z28, 85 Iroc-z
Engine: 3.1L, 350 4 bolt, 350 TPI
Transmission: 700R4, 700R4, 700R4
Axle/Gears: 3.23, Unknown, Unknown posi
Re: 86 TPI....looks like oil in radiator and check out these spark plug pics please
Sounds like a bad head gasket
Old Oct 12, 2011 | 03:15 PM
RAS's Avatar
RAS
I agree, headgasket.
Old Oct 12, 2011 | 04:48 PM
torque_is_good's Avatar
do you have a vacuum gauage and compression tester?
Old Oct 12, 2011 | 04:51 PM
one more thing, please tell me this problem isn't with a vehicle which was listed for $8500???
If it is, and the known problems were discussed with full disclosure then so be it. If there was perhaps misunderstanding, contact the prior owner and discuss his participation in seeking remedy (via cash)
Old Oct 12, 2011 | 05:07 PM
88transam 88's Avatar
Car: 1988 TransAm
Engine: sbc 9:8:1 cr 40os slugs rhs heads
Transmission: th400 3800stall b&mkit manual vb
Axle/Gears: stock
Either way if its the intake or the head gasket intake has too come off dont know the! Whole history on the car can only asume its old
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
db057
Aug 22, 2015 08:17 PM
