Speedo Inop with 5 speed
Car: 1992 Camaro RS
Engine: 3.1
Transmission: 5 Speed
Axle/Gears: 3:42
I bought a 92 RS with a 3.1 and 5 speed. The speedo does not work and my question is does the 5 speed have a vss at the trans or is it cable driven. If it is the VSS type is their any voltage readings that I can take from it to determine if its bad or if the speedo is bad.
Thanks in advance,
Deron
Thanks in advance,
Deron
Car: 1992 Camaro RS
Engine: 3.1
Axle/Gears: 3:42
Re: Speedo Inop with 5 speed
Anyone. If i could find another cluster I would change it out to try it. But i cant find one localy. Been using my gps for my mph for now so at least i know how fast i am going. I also noticed that my numbers on the trip odom. dont change as i drive it either. Thank you again.
Car: check
Engine: check
Transmission: check
The VSS is in the transmission. The ECM buffers the signal and sends it on to the speedometer. See if the cruise control works. If so then the speedometer is most likely bad. Although it can also be the ECM.
The output of the VSS is a AC signal. Can measure it with a DVM.
RBob.
RBob.
[Sold] T5 electric speed sensor
Eric-86sc
Sep 7, 2015 02:10 PM
