85mph Speedo Problems?
Old Oct 15, 2011 | 01:38 PM
Guest
Guest
Posts: n/a
If i were to really bury the needle on an 85 mph unit and i mean if i were to be going anywhere from one hundred to one hundred fifty miles per hour, would that cause any damage to my speedometer, burying the needle like that?
Old Oct 15, 2011 | 10:41 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: 85mph Speedo Problems?
no damage will occur-there is no direct mechanical
linkage from the drive cable to the indicating needle-
there is a aluminum drum connected to the needle
shaft and a rotating magnet inside the drum driven by
the cable-as the magnet rotates,it creates "eddy
currents"in the aluminum drum causing magnetic drag
that rotates the drum against the resistance of the
needle's "clockspring"
Old Oct 16, 2011 | 07:48 PM
Guest
Guest
Posts: n/a
Perfect. Thanks a bunch
Old Oct 17, 2011 | 01:52 AM
blue birdy 87's Avatar
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
Ive put it past the M all the way around, worked fine after!
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
