Odd Sound
Old Oct 25, 2011 | 11:40 AM
Firebird Fly's Avatar
Car: 88 Formula Firebird, 86 Firebird
Engine: 305 TBI and crate 350
Odd Sound
When I come to a stop sign and hold the brake a rattling sound starts. If I put it in park or neutral the sound stops. Ideas?
Old Oct 25, 2011 | 07:32 PM
Jon87Z28's Avatar
Car: 1987 Camaro Z28
Engine: 5.0, 305, Carb
Transmission: Automatic
Re: Odd Sound
Any times that this has happened to me it was due to my cat rattling because it was rotted out and needed to be replaced. Currently I have these symptoms and one of my exhaust tail pipes are vibrating too close to the frame and causing the rattle.
In each of those situations, it only rattled in drive when stopped at a street light or wherever (lower idle than neutral and park).
Old Oct 25, 2011 | 09:00 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Odd Sound
Converter is a good guess. But it could be anything that vibrates at the same resonance as the RPM when you have it in gear. Heat shield or loose interior trim are other possibilities.
Mark_ZZ3
May 24, 2018 01:02 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
