Build up on fuel pressure regulator. Help!!
Old Oct 27, 2011 | 05:52 PM
ungladiador68's Avatar
Car is 1987 camaro 5.0l Iroc z28. I been having fuel problems with this car. Im getting way too much pressure at the fuel rail (65psi.) If im correct it should be around 45lbs. I bought a new fuel pump and a new fuel pressure regulator. My question is upon replacing the fuel pressure regulator when i took it off i have found some kind of while build up on the inside. It looks like is could be sand or sugar but when it dries it becomes like white powder. Im hoping that someone here can help me out or if anyone has seen this before. At this point i dont know which way to proceed. Should i flush the gas tank and or gas lines or just clean aroung the regulator and reinstall along with the pump. Any help would be appreciated.
thanks
Old Oct 27, 2011 | 08:08 PM
ex-x-fire's Avatar
Re: Build up on fuel pressure regulator. Help!!
Sounds like the return line is plugged up, Do you have any enemies? Some have been known to put sugar in the gas tank. I'd clean everything up since you have the tank out. Use compressed air to blow out the lines.
Old Oct 27, 2011 | 10:47 PM
Wow..You were right .took the fuel rail off and the return line is clogged with that stuff. I am not sure if its sugar or sand or just build up. i dont really have any enemies an the car is always in the garaged except once in a while for rides. I am going to try blowing out the return line .and im going to drain the fuel tank.and blow air through the lines. Install a new Ac delco fuel pump a new fuel filter a new adjustable fpr. Any other suggestions. is there an easy way to check if the injectors are clogged? i really dont want to do this again.
thanks again
Old Oct 28, 2011 | 06:14 AM
ex-x-fire's Avatar
You might be better off if you ship the injectors out to have them cleaned/tested.
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
92camaroJoe
Aug 13, 2015 06:07 AM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
