85 tpi will not start
Old Oct 30, 2011 | 10:45 AM
c4mo's Avatar
As I was driving my car home one day it started popping and missing. I got out to check if any of the plug wires were loose, one of this was, but when I tried to restart it, it wouldnt crank. I've check the normal things thus far. Fuel pressure is 38 psi, it's firing, hasnt jumped time, and the ignition module I had checked is fine. Ive even tried spraying starter fluid down the intake, but it will not make it run, ideas? Thanks
Old Oct 30, 2011 | 07:41 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 85 tpi will not start
You mean it wouldn't fire up?
That would suggest a elec/ spark problem
How good is the spark? .
Old Oct 30, 2011 | 09:05 PM
dans89's Avatar
Car: 85 z28
Garantee you that its the ignition control module. They always test good. The reason is that fail when they get hot. I bet money that if you spend t the 20 bucks and buy one it will fire up first try.
Old Oct 31, 2011 | 06:29 AM
c4mo's Avatar
Yes, i mean it wouldn't start up. The spark looks to be strong. After working on it yesterday I verified I had a full 12v to the coil which I did. The primary resistance on the coil is good reading 1/2 ohm and I work at a parts store where I checked the ign module multiple times till it was hot to touch where it passed each time. I would think it would start at least a little while and then shut off, if the module was the problem. Ill try a module today anyway. I do agree that it's some kind of spark issue because it smells like gas after cranking it. To me saying it's all unburnt. I'm open to trying whatever more. Thanks
Caspar
Jun 19, 2016 11:19 PM
Wade787b
Sep 29, 2015 01:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
L98GTA87
Aug 5, 2015 11:02 PM
