Where is the oxgen sensor located in a 1989 Chevy Camaro RS?
Old Oct 31, 2011 | 06:31 AM
89RSRedConv's Avatar
Ok, I found one in the engine bay, one wire. Is there another one? and if so where? and if I buy the Bosch OEM replacements are they the same or what? some are listed as "upstream"? Am I going to need the special wrench for these?
Sorry guys just hoping someone could shed a bit of light so I can get these ordered and on the way for the weekend .... still chasing the "surge".
Old Oct 31, 2011 | 06:36 AM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Re: Where is the oxgen sensor located in a 1989 Chevy Camaro RS?
My car only has one, right before the Cat Converter
Old Oct 31, 2011 | 08:32 AM
That's great and the picture helps a lot. I ordered two Bosch and will give them a shot this weekend. Hopefully it fixes the "surge" issue
Old Oct 31, 2011 | 08:34 AM
58mark's Avatar
I have a 6 cylinder car, I don't know if it's the same on every car
Old Oct 31, 2011 | 02:11 PM
torque_is_good's Avatar
on the 305 you only have one and it's located on the collector of the driver's side header. I can't tell you where it is if you are running with restrictive exhaust but I didn't need an O2 extension so it must be on the y pipe but i yanked the stock exhaust when i bought the car and can't recall its exact location on stockers
Old Oct 31, 2011 | 02:14 PM
Twin_Turbo's Avatar
It's in the drivers side manifold, at the bottom of the casting where the connection to the Y pipe is.
Old Nov 1, 2011 | 07:48 AM
Thanks guys I will be waiting for them to get here ... If I start her up and she starts "surging" if I unplug the sensor would I be able to determine if the sensor is bad? Wouldn't it run like garbage?
9192camaro
16
Feb 3, 2019 12:21 AM
kyleb24
Aug 15, 2015 08:24 AM
Rustyweb7
Aug 9, 2015 03:05 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
