No fuel when cold outside. Could this be ECM related?
Old Nov 3, 2011 | 12:05 PM
robster186's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
I have been fighting the same problem for 4 weeks now.I am down to thinking its ECM related? '91 Z28 5.7 TPI. I have put in a new fuel tank, fuel pump, fuel filter, TPS sensor, ECM temp sensor and pigtail,new fuel regulator, fuel rail seals, new upper and lower injector O rings, new ignition module, new idle control valve, coil wire, cap, plugs, rotor, wires. When it is cold outside ( below 55 degrees) it will not start.I can hear the pump click on, but no pressure at the Shrader valve. Once the day warms up, it will start and start every time all day long and evening until the next morning and it wont start then. Yesterday morning, I put a small heater in the passenger floorboard, aimed at the kick panel, for about 15 minutes. Got nice and warm and it fired right up. Did the same thing this morning. Could ambient temp really affect the ECM? Should I just replace the entire ECM? Still needing help guys. anything would be greatly appreciated.
Jae992
Aug 27, 2015 09:07 AM
86IROC112
Aug 21, 2015 07:20 PM
Winchester1094
Aug 18, 2015 10:23 AM
