89 iroc missing trouble
Old Nov 4, 2011 | 03:17 PM
dan68rs's Avatar
Car: 89 formula
Engine: tpi 350
Axle/Gears: 95 z 3.42
i have an 89 iroc that just started cutting out after about mid throttle, changed the tps, icm, ecm, injectors, have not checked the pickup coil, one thing i did find is that it will stop missing/cutting out if the timing wire from the computer is disconneted, the one that you unhook to set the timing. and it does this with both computers that i have.
Old Nov 22, 2011 | 05:26 PM
dan68rs's Avatar
Car: 89 formula
Engine: tpi 350
Re: 89 iroc missing trouble
turned out to be a loose connection on the main harness ground causing the miss, the timing retarding is because of the knock sensor is the wrong one.
Old Nov 22, 2011 | 05:49 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Thanks for posting the root cause.
Raul
Old Nov 22, 2011 | 07:48 PM
dan68rs's Avatar
Car: 89 formula
Engine: tpi 350
Not a problem, i got this car and someone changed the 305 out for a 350 vortec block so im chasing alot of issues.
evilstuie
Apr 14, 2016 08:52 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
mhatfield 14
Oct 24, 2015 07:48 AM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
mustangman65_79
Aug 11, 2015 03:17 PM
