throttle not opening all the way
Old Nov 6, 2011 | 08:16 PM
A K racin's Avatar
i noticed that when the gas pedal is pushed to the floor my throttle body does not seem to open all the way, i can push open all the way from under the hood i adjusted the tv cable and still th same thanks
Old Nov 7, 2011 | 07:47 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: throttle not opening all the way
Common issue on our 3rd gens. If there is a floor mat move it out from under the go-pedal. If that doesn't do the trick then pull back the carpet and remove some of the padding from under the go-pedal.
Note that the TV cable adjustment doesn't have anything to do with the TB opening issue. Be sure to have the TV adjusted correctly. And do the adjustment under the hood by manually moving the throttle lever, not by flooring the go-pedal.
RBob.
Old Nov 7, 2011 | 09:28 AM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Transmission: 700R-4
Axle/Gears: 327
GREAT THANKS thats how i noticed the tb was not opening all the way will take a look later today
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
GouldyGTR
Sep 7, 2015 09:05 PM
Kenwood
Sep 4, 2015 05:50 PM
luvofjah
Sep 3, 2015 07:08 PM
