alt. wont charge battery after swap
Old Nov 6, 2011 | 09:40 PM
Grizzlybear226's Avatar
Car: 1988 Trans am
Engine: 358
Hey all. I recently just finished my 305 tbi to 350 carb swap in my 88 t/a and it turned out better then I could've hoped for but there's only one problem, after the swap I noticed that the alternator isn't charging and I can't figure out why. I got the alt tested today, its fine and works the way it should. Is there something to do with me elminating the ecm that the alt wont charge the battery anymore, do I have to rewire it. Any help is appreciated
Old Nov 6, 2011 | 10:11 PM
89rs454's Avatar
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
Re: alt. wont charge battery after swap
What year is this 350? That would help a lot, It's easy to wire up.
Old Nov 6, 2011 | 10:16 PM
Car: 1988 Trans am
Engine: 358
Its a 87 350 and the alt is a stock unit from my 88 305
Old Nov 6, 2011 | 10:32 PM
89rs454's Avatar
Car: 1989 SS
Just wire it up they way it was stock? The pcm has nothing to do with the alt.
Old Nov 6, 2011 | 10:36 PM
89rs454's Avatar
Car: 1989 SS
how many wires does you alt have on the plug?
Old Nov 6, 2011 | 10:39 PM
Car: 1988 Trans am
Engine: 358
That's what the problem is, I have hooked up the stock wiring and its not charging the battery at all.
Old Nov 6, 2011 | 10:51 PM
89rs454's Avatar
Car: 1989 SS
What about your fan switch relay? I know my alt 12v switched went through that, give that a check.
Old Nov 7, 2011 | 07:44 PM
Car: 1988 Trans am
Engine: 358
Checked all the connections today and while the cars running the battery was at 13.5 volts so im guessing my gauge is broken. How easy is it to hook up a aftermarket ammeter gauge and what points to you use.
Old Nov 8, 2011 | 04:31 PM
Pocket's Avatar
Car: 91 Trans Am
Use a meter to test voltage when running
13.5v is a little low, but your alt is charging. 11.5-12v is battery power only
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
