85 305 TPI Running like dog ****
Car: 85 z28
Hey guys, today I went out to fire up my 85z to warm up so I could go to work, and it was/is running really rough and idling up and down, and it was running rich as hell. It drives down the road just fine sometimes, and sometimes it cuts out randomly and the whole car shakes, almost like a miss. When ever i stop at all it dies randomly. About a month ago I was having the same issue, and it threw a ECM/PROM code, so I pulled the computer out of it and checked the PROM and everything was ok, so I plugged it back in and everything has been ok sense. I put a new ICM in it back in FEB, a Hayden fan controller and a new CTS for the gauge last weekend. Any ideas?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 85 305 TPI Running like dog ****
injectors !!! You should do a upgrade to the 1227165 ecm. I hate that 1226870 nothing but trouble.
Car: 85 z28
What makes you so sure of injectors? Its hard for me to put goodies on the car sense its my DD. I forgot to add that the SES light flashes really fast most of the time, and other times it stays on solid.
Car: 85 z28
Not sure yet. ill go pull em now
EDIT: Its throwing a code 51
Engine: Lb9
Transmission: M20
sounds like your in LHM, you may still have a bad ecm ! If you need me to burn you a eprom let me know.
Sanjay
Aug 12, 2015 03:41 PM
