how to check ignition switch
Car: 1989 Pontiac GTA/2007 TrailblazerSS
Engine: 350 L98/LS2
Transmission: 700-R4/4L70E
Axle/Gears: 3.27/4.10
how can i test my ignition switch to see if i need to replace? my concern is that i'm getting no spark to my distributor and i've already gone through a system check chart on how to diagnose the no spark.
tests i've completed lead me to either a few choice wires or connection at the ignition switch.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: how to check ignition switch
turn the ignition switch to the accessory position and see if you have power at the pink wire on the coil.
Engine: Lb9
Transmission: M20
92camaroJoe
Aug 13, 2015 06:07 AM
