Low oil pressure, no noises drops as motor gets to operating temp. HELP!
Old Feb 19, 2014 | 08:19 PM
  #51
JrBrein1988's Avatar
Car: 1988 Pontiac Firebird
Engine: LO3 5.0 (305) TBI
Re: Low oil pressure, no noises drops as motor gets to operating temp. HELP!
My '88 Firebird has been having the same problems lately. Oil pressure will drop to near zero or below, once heated up to normal operating temp. I took it to the shop and they found normal oil pressure readings with a mechanical gauge. They replaced the sending unit and it didn't fix the problem. Runs normal, no noises or knocking. Any ideas?? I'm guessing it's the gauge itself.
Old Feb 19, 2014 | 10:35 PM
  #52
David Dempsey's Avatar
Car: 92 Firebird
Engine: 91 350 TPI
It was my gauge. I had swapped instrument clusters because one had a bad odometer, and that gauge just read low. When I swapped the old gauge into the new cluster, it was all good.
Old Mar 8, 2014 | 06:45 AM
  #53
Car: 92 Firebird
Engine: 91 350 TPI
As a follow up to my follow up, it was the gauge. After almost 3 weeks, the pressure never drops below 15psi. I guess they just go goofy at some point. It's not that bad to swap them out and I had a spare, but I would go junkyard hunting for another before I did anything serious there. I ended up getting a new sending unit installed for nothing.
theshackle
Sep 17, 2020 08:26 AM
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
ChevyZ71
Aug 13, 2015 07:30 AM
92camaroJoe
Aug 13, 2015 06:07 AM
