85 TPI TA wont start
I got an 85 TPI TA and it will not start when cold unless you give it a shot of starting fluid and it starts right up and runs fine. maybe the cold start injector or PCM?
Thanks in advance
Thanks in advance
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 85 TPI TA wont start
cold start injector, or bosch switch in manifold or relay sound's like your on the right track.
Engine: Lb9
Transmission: M20
http://chevythunder.com/fuel%20injec...g%20pg%20D.htm
upgrading to a 86-89 1227165 ecm with the $6e tune is a good upgrade
http://www.eecis.udel.edu/~davis/z28/ecm_swap/
Sanjay
Aug 12, 2015 03:41 PM
