quick ignition coil question
Car: 1990 camaro rs
Engine: 5.0L 305 tbi
Hey guys, so i wanted to replace my coil while doin a tune up and noticed the stock one has the mounts ruveted to it. I checked all the replacement coils and none of them come with a mount so do i really have to find a way to drill the rivets out and find some thin bolts or can i buy one somewhere? Hope yall know what im talkin about and its a 90 camaro 305 tbi
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: quick ignition coil question
Correct. Chisel the heads off or drill them off- whatever floats your boat. The old rivets come out and your replace them with either new rivets (commonly available pop rivet guns usually come with an assortment) or you replace them with an appropriate nut and bolt combo. I like using nuts and bolts becuase you can remove them any time you want after that.
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
my preferred method is to cut the rivets off with a chisel on both ends and pry the brackets off the old coil.
the replacement coil should come with nuts and bolts.
Car: 1990 camaro rs
thanks, i guess i'll take it off today and take it on the ship tomorrow and see if i can get it off, hopefully it all goes well
92camaroJoe
Aug 13, 2015 06:07 AM
