92 help
92 help
92 305 idle issue sometimes high then goes down once in blue moon low a/c affects its if I turn on idle drops doesent appear to be vac leak new Idle air put in im aimong for just doing a tune up having timing checked ideas? Stock 305 tbi 92 rs
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: 92 help
Do you have any exhaust leaks? Mine had the same issue, and the exhaust had leaks. Repaired the leaks and the idle smoothed out.
