car wont start
Car: 89 Camaro RS
Engine: 2.8
car wont start
Hey hope someone can help just replaced intake manifold gasket, valve cover gasket nd every gasket above that nd installed new distributor cap and roter but car won't start....it used to run just fine except for a massive oil leak a week ago ever since then car just sat in garage...idk wuts wrong any suggestions....car is 89 RS v6 173
Re: car wont start
does it crank?
if so, your timing is off. Find tdc on #1 and connect your plug wires accordingly. Or, remove the distributor and try stabbing it again
