Need Camshaft Recommendations
Old Nov 16, 2011 | 08:00 PM
akanitro's Avatar
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
OK, I am rebuilding the engine in the GTA and I need some help with what cam to get. I am going 0.030 over with flat top pistons, balance and blueprint everything. Everything else is stock as I want this as a daily driver and want everything to work in unison and run smooth with no problems. I am also upping the spring rate to match the cam so I need recommendations also. Also, going with LT1 injectors too. I have heard of using the ZZ4 cam or the LT1 Hot cam but any input would be greatly appreciated.
Thanks in advance.
Josh Jacob
Old Nov 16, 2011 | 08:05 PM
akanitro's Avatar
Re: Need Camshaft Recommendations
Also, what other upgrades should I do at this time. I want to keep the stock exhaust manifolds and intake so everything looks and functions completely stock. Basically, just internal work.
Old Nov 17, 2011 | 12:29 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Exhaust upgrade is one of the best bang for $$ mods.
Little point in doing internal mods if gases can't get away
Old Nov 17, 2011 | 12:51 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I say this frequently and will say it again: http://www.cammotion.com/ContactUs.aspx
If you want a cam recommendation then get one from experts like the folks at Cam Motion... End of story
Old Nov 17, 2011 | 01:18 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
I am thinking of going this route. See my old cam in sig. I need something that will run circles around this old cam and put me in the low 11's with the set up I have now, although, I'm not sure if it's possible or not?
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
PurelyPMD
May 5, 2016 04:57 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
GTAman
Sep 26, 2015 02:01 PM
