'83 Camaro z/28
Old Nov 21, 2011 | 07:08 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
'83 Camaro z/28
Why does my car have an o2 sensor? It's an LG4 car, and it's carburated? Although the carburator does have a bunch of electrical crap on it.
Just trying to figure this thing out. I plan on putting a regular carb on it with none of the EGR crap. Do I need an o2 sensor? I'm gonna do headers, just wondering if i'm gonna need to weld in some o2 bungs.
Please give me some insight.
And ya, I've been searching. If anybody knows of a thread with detailed info about an '83 that would be awesome. Thanks Guys/Gals.
Old Nov 22, 2011 | 10:51 AM
MD83Z's Avatar
Re: '83 Camaro z/28
The 83 LG4 uses a computer controlled carb and distributor. You can get a vacuum advance distributor and non CC carb that doesn't use the oxygen sensor or computer.....Then you will need to manually or vacume control the automatic transmission overdrive lock up..... There are hundreds of threads on this, in the carb section....
Old Nov 22, 2011 | 10:55 AM
MD83Z's Avatar
Re: '83 Camaro z/28
Ok....with the t5 you onlly need a carb and a dist. Mine were cheap at the junk yard...You can also remove the wire harness that connects the computer controlled stuff.
Old Nov 22, 2011 | 09:25 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Re: '83 Camaro z/28
Thanks, and sorry I searched. There is just so much info on this whole forum that it's getting hard to find anything.
So, where is the computer at? And how the heck does the computer control a carburator?
Old Nov 23, 2011 | 11:00 AM
MD83Z's Avatar
Re: '83 Camaro z/28
computer is under the dash....wire harness comes out under passenger fender and into engine bay. The CCcarb has throttle position sensor and another I guess fuel or idle electric control....The CCdistributor uses the computer to advance the spark (no vacuum can) and the O2 sensor sends info computer that ultimately adjusts one of the (guess its an electric fuel control) carbs rich to lean modes.... When everything works it is a good system, I drove mine for 200k rarely changing anything other than plugs, and gave good gas mileage. The old school system with non cc carb that i have now eats gas
Old Nov 23, 2011 | 11:25 AM
MD83Z's Avatar
Re: '83 Camaro z/28
I also suppose a car from Canada would not be computer controlled.
Old Nov 23, 2011 | 09:17 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Re: '83 Camaro z/28
OH ok thanks. Mine runs awesome for what it is. It sometimes loads up a bit at idle. Mine only has 89k on it. But it's just a fun car so i'm not worried about fuel mileage, which currently is horrible anyways, Especially for being such a gutless 305.
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
69 Six Pack
Oct 5, 2015 07:51 PM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
