tire squeeling sound while driving
Old Nov 24, 2011 | 11:57 AM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
When I drive I hear a noise that sounds like the tires are
spinning in place but I'm just barely tapping the gas to accelerate and it still does it. Anything past like 10mph the noise comes. I was thinking the brakes are dragging? but that sounds more high pitched, like a squeek so I'm not sure where to start first. what do you guys think?
Old Nov 24, 2011 | 12:02 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: tire squeeling sound while driving
Put the rear of your car up in the air and see if both your rear wheels turn okay.
I'd then check your toe. There are videos online about how to check your toe-in at home.
http://www.youtube.com/watch?v=W8qFjAB67vk
You need jackstands, string, and as accurate of a ruler/caliper as you can get.
Old Nov 24, 2011 | 03:18 PM
Cosmik Debris's Avatar
Alternator belt slipping?
Old Nov 24, 2011 | 03:24 PM
bitchin_buick's Avatar
Car: 91' bird(WS6>>305TBI), 82'Regal
Another possibility, could be the U-Joints on your drive shaft.......
Old Nov 24, 2011 | 07:58 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Brake pads worn out? - might be the indicators dragging on the discs.
Old Nov 25, 2011 | 06:58 AM
0pyders's Avatar
nah the brakes weren't worn at all when I started this project. It's just been 2 years since I have driven this car so maybe the pad is rusted to the disc I don't know But I'm gonna go check all for wheels for dragging right now just in case.
I think my toe is screwed up too like infernal vortex was sayin because I remember replacing the front steering pieces but I didn't look at how much the tie rods should be screwed in, etc.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
gta power
Aug 13, 2015 06:15 AM
mustangman65_79
Aug 8, 2015 12:07 PM
