Oil Ring sizes??
Old Nov 25, 2011 | 09:37 PM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
Oil Ring sizes??
I have an 89 tpi 350 8 engine code, I just ordered a set of total seal gapless rings. The top and second rings are direct replacement and fit just fine. The oil ring however; does not. the width of the oil rings is probably 1/16" wider than the stockers were, so when they are installed on the piston you can visibly see that the oil rings stick out of the edge of the piston just enough to make them way too tight to install. I tried to install one piston and it was a fight to get it in which i knew wasnt right.
Any help would be great since i wont be getting the engine assembled this weekend!
Old Nov 26, 2011 | 12:58 AM
ex-x-fire's Avatar
Re: Oil Ring sizes??
Are you using a piston installer?
Old Nov 26, 2011 | 06:52 AM
grumpyvette's Avatar
If you have ther correct ring set,it sounds like the oil ring expanders not correctly assembled with the twin wipe rings
http://forum.grumpysperformance.com/...3814&start=230
http://forum.grumpysperformance.com/...php?f=53&t=247
http://forum.grumpysperformance.com/...hp?f=53&t=3897
Old Nov 26, 2011 | 10:34 AM
Sounds like you have stock pistons with the shallow oil ring groove design.
No option available other than, get the right (shallow) rings.
Old Nov 26, 2011 | 01:24 PM
monte-ss's Avatar
http://www.cardomain.com/ride/319282...e-carlo/page-8
Here is a pic of the rings I would assume the shallow ring option is probably the case. I can put the rings in the cylinder and have no issues the end gap is good, its just when its installed.
toronto formula
Nov 10, 2015 06:17 AM
Brother Al
Oct 14, 2015 06:39 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
Navy8125
Aug 21, 2015 09:32 AM
