rough idle but no stall
Old Nov 26, 2011 | 07:03 PM
blue iroc's Avatar
Car: 1989 iroc
Engine: 5.7 L98 tpi
Transmission: TH700-R4
Axle/Gears: 2.77
I own 89 iroc 5.7 that recentlly started to hunt for idle, idles rough but doesnt stall. The car actually runs really good when on the street. The following have been recently installed cap, rotor, plugs, iac, battery, coolant temp sensor, starter, and starter remote selenoid.
When cold the car idles good with only a hint of idle hunt. Once, the car warms up the idle begins to hunt from 500 to 700 rpms. It started to hunt for idle after I used throttle body cleaner on the tb and iac hole.
Car is not throwing any codes, what could be wrong? Any help is appreciated
Old Nov 26, 2011 | 08:39 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: rough idle but no stall
Maybe a vacuum leak?
Old Nov 27, 2011 | 04:29 PM
blue iroc's Avatar
Car: 1989 iroc
Engine: 5.7 L98 tpi
Axle/Gears: 2.77
Thanks for the reply camaronewbie. I found a vacuum leak at the t connection leading into vacuum reservoir. That did change the idle hunt. I disconnected maf and the car ran smoother with a slight idle hunt. Could that be it? The check engine light only lights because of mas being disconnected. I'm getting frustrated, I need help.
Old Nov 27, 2011 | 05:33 PM
Car: 1992 RS
Engine: Carbed 350
No expert on MAF stuff here so can't help any further - but any car can "hunt" for an idle with a vacuum leak and so I thought I'd throw it out there.
jklein337
Sep 19, 2018 06:23 PM
greenyone
Sep 2, 2015 03:39 PM
IROCtometal
Sep 2, 2015 02:01 PM
JHX
Aug 29, 2015 02:30 PM
