92 z28 ignition or starter ? clicks then starts
Old Nov 29, 2011 | 07:50 PM
Anthonypudda's Avatar
when i turn key over the engine just clicks once then nothing, I repeat the process two or three times then, engine starts fine. When i turn it off and try to start again it takes a couple more times before starting. Should I change starter? this is my first post, but I've been a fan of this site for a while now!!
Old Nov 29, 2011 | 08:28 PM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Re: 92 z28 ignition or starter ? clicks then starts
Make sure you battery terminals are tight. Clean them up if needed. If that doesn't fix it have the starter tested.
Old Nov 29, 2011 | 08:34 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Usual fault is contacts in the starter are worn; not making perfect contact
assuming your battery is good and batt cables have good clean / tight connections at both ends
Depending on starter type ,often the contacts can be removed and rotated 180 degrees to give a new contact spot without having to replace the contacts ( cheaper than a new starter)
Old Nov 29, 2011 | 09:29 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
It's probably your ignition switch. Do you know how to start your car at the starter itself? If it starts fine that way , it is more than likely your ignition switch.
Old Nov 29, 2011 | 10:35 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Mine did something similar. It ended up being the starter enable relay in the drivers side kick panel
BRoss99
Aug 10, 2025 05:08 PM
Caspar
Jun 19, 2016 11:19 PM
justin57
Aug 20, 2015 07:05 PM
86Base
Aug 8, 2015 01:34 PM
