screw in studs and stock rocker arms
Old Nov 30, 2011 | 03:30 PM
afida15's Avatar
I know this may sound stupid to most people but ive got a set of 601 heads im putting on my 350 with screw in studs and was wondering if im able to use the stock rocker arms until i can upgrade to rollers? thanks
Old Nov 30, 2011 | 03:35 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: screw in studs and stock rocker arms
studs should be the same with the exception of being screwed in instead of being pressed in. so stockers should go on just fine.
Old Nov 30, 2011 | 03:40 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
depending on what roller rockers your going to use if there not self aligning nows the time to get the machine work done if it has not already been done.
sweet_87_iroc
Sep 25, 2015 10:01 PM
camaro71633
Sep 1, 2015 10:24 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
Cameeeero
Aug 20, 2015 03:06 AM
