turns off while slowing to a stop
Old Dec 4, 2011 | 09:35 PM
saldav420's Avatar
Car: 86 bronco, 88 iroc
Engine: 351 windsor, 350 tpi
Transmission: 700r
I need a little help, I have a 88 iroc 5.7 tpi. recently my car has bein idling rough, but most recently it's bein shutting of as a slow down to a complete stop, it idles high then real low then shuts down. Could anyone help me with this issue. thank you in advance.
Old Dec 4, 2011 | 09:51 PM
justcallmeclassy's Avatar
Car: 1992 Camaro RS Z03 T-Top
Engine: L98 with TBI
Axle/Gears: 2.73...
Re: turns off while slowing to a stop
Idk about the high idling, but you should look into maybe your fuel lines etc. Mine were severely clogged, and would idile rough and die a lot when I got off the gas. New pump new lines and completely cleaned tbi and injectors completely fixed it. Gonna be different on tpi but same idea. But then again it could be something completely different idk.
Old Dec 6, 2011 | 06:38 PM
87whiteiroc's Avatar
Car: 87 Camaro
Engine: 5.7 350 TPI
check the o2 sensor on the drivers side exhaust manifold/header. I would always have to let the car warm up way past closed loop to heat it up enough. It revs up then idles real low because the ecm keeps getting a different temp reading from the junk sensor. Other times I would have to drive 3 footed part of my foot on brake and gas and other on the clutch pedal to keep it running at stop lights. Replace the sensor, I'm sure it will help some.
Prodigious
Nov 7, 2020 09:23 AM
pfsteichen
Feb 9, 2016 06:59 PM
Wade787b
Sep 29, 2015 01:15 PM
dibella989
Sep 1, 2015 04:12 PM
saldav420
Aug 28, 2015 02:02 AM
