Inermittent high idle ?? 305 TPI
Old Dec 9, 2011 | 04:47 PM
labdog's Avatar
I have a 1986 305 TPI in my street rod. It just developed a problem at idle. It stars fine idles .but when driving every other time you come to stop it will idle high. Any ideas. Thanks
Old Dec 9, 2011 | 05:09 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: Inermittent high idle ?? 305 TPI
Is your AC on?
Old Dec 9, 2011 | 06:17 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
a/c on or even the defroster since that will kick the a/c pump on and cause a high idle.
Or, check for vacuum leaks. Clean the throttle body, IAC valve. hows the timing?
Old Dec 10, 2011 | 05:08 PM
labdog's Avatar
Cleaned IAC and Throttle body also disconnected battery to reset. Test drove so far so good.
BlueIroc-Z
Jun 9, 2019 03:22 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
