Plug ontop of Igntion Coil
Old Dec 13, 2011 | 09:16 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
The 90 Formula with TPI needs a new connector on top of the coil. Sometimes the car will stop running, and wiggling these wires will fix it.
There is one item order from a dealership now; but I'm not sure if it's the proper one. The search only reveled one part number at the dealer. There are two plugs on top of the coil. I need the one in front, circled in the photo.
The formula must not have the factory plug as the wire has some heat shrink a few inches up.
90 Formula:
Here's the factory 91 GTA for reference.
Here's a wiring diagram I got from MSD.
Anyone know more about where to get the proper plug? I just found one in the link below at Napa; not sure if it is for the front or rear however.
http://www.napaonline.com/Catalog/Ca...RecType%3aA%29
Old Dec 15, 2011 | 03:50 PM
1killerolds's Avatar
Re: Plug ontop of Igntion Coil
go to rockauto.com they have them both, the black and the grey. find them under "Electrical-connector, Ignition coil connector"
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
morrow
Jan 13, 2024 12:29 PM
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
rjcme
Sep 5, 2015 01:23 PM
