broken valves,help....
Old Dec 14, 2011 | 01:27 AM
HorsePowerJUNKI's Avatar
Car: 86 trans am gta,and 88 corvette
Engine: TA-355ci tpi,vette 383 tpi
Transmission: 5spd manual,700r4
Axle/Gears: borgwarner 370 posi,vette is stock
has anyone ever experianced this problem? i got a large cam and springs to match.after market keepers and locks.same stock valves but new,the engine is tuff as hell, totaly rebuilt 355tpi.it runs great until it pops the top off a valve (on the lower of the two grooves on the stem)were the seal goes below the locks.its happened 6 times on random valves.ive been told that the stock valves cant handle the spring rate.and they are snaping off because the presure of the spring when the valve close's is to much because the lift is so much .512/.520 i had the guides machined down so the keepers wont smash the seals.its breaking when the valve closes. do they make after market valves without that lower groove for the seal ? any input would be apreciated.thanx
Old Dec 14, 2011 | 07:08 AM
Re: broken valves,help....
Virtually ALL aftermarket valves lack that groove, because that seal is so worthless.
For a cam as mild as you describe, you don't need anything really spendy; just something hard enough that you can't scratch it with your thumbnail like the stock crap. I'd suggest the Manley "Street Flo" valves... they're about the cheeeeeeeeeeeepest "good" valves out there, at around $90 a set. http://www.summitracing.com/parts/MAN-10722-8/ and http://www.summitracing.com/parts/MAN-10765-8/
Old Dec 14, 2011 | 07:37 AM
grumpyvette's Avatar
if your busting valves or any valve train component,you have a valve train clearance or geometry issue your ignoring
its just that simple, yes I'm sure you think everything's great, but if you take the effort to carefully verify ALL VALVE TRAIN clearances and geometry , youll locate the reason why your having durability issues, take the time to find,isolate and fix it, its NOT LIKELY TO BE a valve spring load rate issue, theres no evil sorcerers curse its just a fact that if parts break theres a CAUSE and in most cases its the wrong clearance or a geometry issue or lack off lubrication
read thru this link and sub links
http://forum.grumpysperformance.com/...php?f=52&t=181
http://forum.grumpysperformance.com/...php?f=52&t=399
http://forum.grumpysperformance.com/...php?f=52&t=401
http://forum.grumpysperformance.com/...ushrods#p18267
Old Dec 14, 2011 | 09:42 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
I don't know - just surmising - but would a spring or retainer bind cause the valve tip to break? In these conditions the valve stem would be free floating or in compression, wheres I would assume a tension condition would be needed to pop the valve tip off below the locks. Like say in float when the valve suddenly slams closed.
Doesn't this also mean a bunch of valves have disappeared into the cylinders, with resulting carnage?
Bubbajones_ya
Jul 6, 2024 08:32 PM
skeltor
Feb 2, 2016 10:37 AM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
m00n420
Sep 11, 2015 02:39 PM
