What does this compression test tell me?
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: What does this compression test tell me?
Do you have the same cylinder heads on both sides of the car? Ever had the engine rebuilt? Really weird that all the ones on the passenger bank are lower than the ones on the driver's bank.
Car: 87 Iroc
Engine: built 355, 450HP
Transmission: built 700r4
looks like you might need a rebuild. there should be 10% difference between the highest and lowest.
Car: 1985 Camaro Iroc
Engine: 350 tpi
The engine has been rebuilt. Currently has 170k miles. Also wanna note this test was before the vacumm leaks and idle issues were resolved. I have not checked the cylinder heads. I find this strange as well.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Do the test again but this time squirt some oil into each cylinder before testing it.
Do it again; but this time, use a hot battery, and blokc the throttle wide open.
Car: 87 IROC L98
Ooh. I forgot about saying to do it at WOT.
Elephantismo
Feb 13, 2019 12:51 AM
WhteRbt
Sep 21, 2015 09:48 AM
