Fuel System Help...
Car: 1984 Camaro Z28
Fuel System Help...
So I am wondering if this is possible, I want to drain all the old gas out of my firebird in a few days so I was wondering I read a few months ago that you can take off the fuel lines from the motor and run them into a jerry can and manually control the pump via the OB II connector under the dash, So what exactly I mean is the you can run a lead into the fuel pump connection to power so that the fuel pump will turn on then im going to run all the crap gas into the jerry can then replace the fuel filter and run good gas through the car unless I can run the car on the bad gas somehow I am guessing it turned to varnish by now since it has been sitting there for 3 years...
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fuel System Help...
You can jumper 12v from the battery to the fuel pump relay easier and accomplish the same result
Find the relay near the booster with the small red wire sticking out that's not connected to anything. Thats the prime or test lead. Add 12v there and the pump will come on if its in working order and the wiring is intact
you must be talking about g in the aldl ?
just really cant think straight about anything right now my girlfriend just broke up with me cause apparently she doesn't want to cheat on me, nice way of saying there was nothing between us...
Engine: Lb9
Transmission: M20
Using a paperclip, jumper the orange power supply wire to the grey fuel pump feed wire, the relay is the center relay in the group if this douse not have the test lead.
I decided not to buy it, might aswell stick to my 88 Camaro :P i am got it home it was spent almost a week on a hoist since the tire machine in shop class broke down...
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
beachrodder
Aug 25, 2015 08:05 AM
