Confused about timing mark
Old Dec 22, 2011 | 08:06 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Hi Guys,
I had to buy an adjustable timing tab for my new 8" balancer. So I used a degree wheel and found TDC (0* degrees) and pointed the red arrow in the picture at it. However, the white 0* mark on the balancer doesn't match the true 0*. Should I etch a new line on the balancer at the true 0* mark and paint black over the existing timing marks?
Any help would be appreciated.
Thanks!
Old Dec 22, 2011 | 08:12 PM
Re: Confused about timing mark
If you have an adj pointer, no need to mess with the damper; just set the pointer to point at the 0° mark on the damper when the piston is at TDC.
That's really all you need, in the RW, is for the pointer to point at the mark when the spark occurs at 0°. No need in worrying about the degree wheel which won't be in place later on anyway. It'd be luvly if everything all matched up, but this is the RW, and things don't always work out so perfect out here. Concentrate on what matters to your long-term success FIRST.
Old Dec 22, 2011 | 08:42 PM
That totally makes sense. I moved the pointer and left the balancer alone. A big DUH to me! But at least I'm learning
Thanks a million (again) Sofa!
Old Dec 22, 2011 | 09:00 PM
Damon's Avatar
Wow, that thing is off by 10*!?!?! That's a MASSIVE mismatch. Never seen a new one out of the box be off by more than 2 unless it was defective or the wrong one for the engine.
Balancers for use with common "1:30" position timing tabs like yours should have the timing line exactly 13* offset vs. the crankshaft key location (which is in-line exactly with the #1 crank journal on EVERY small block Chevy ever built right back to 1955). It's difficult to be off by that much just from production line tolerance stacking.
You absolutely sure?
Old Dec 22, 2011 | 09:15 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Originally Posted by formula_novice
Hi Guys,
Thanks!
You need to make two marks on the balancer and right in the center is your TDC. For example: Find TDC by using a piston stop. Ok, mark your balancer where it meets the zero on your timing tab. Now, turn the engine the opposite direction until it stops again, and mark at 0. Then take a measuring tape and mark right in the middle of the two lines on your balancer. That should be your TDC.
Old Dec 22, 2011 | 09:27 PM
My 383 shortblock is from BluePrint and I'm using the 8" balancer they said they use (Professional Products 80003).
This is the first time I've done this. Here is what I did... I put a piston stop on the deck and turned clockwise until the piston hit. Set my wire marker to point at 0* on the degree wheel. Then turned it counter-clockwise until it hit the piston stop which was 30* on the degree wheel. Divided 30 by 2 = 15*. Moved the balancer to point to 15* at my wire marker. Finally, I moved the adjustable timing marker to point to the 0* mark on the balancer. Is this wrong?
Old Dec 22, 2011 | 09:50 PM
ninetyone's Avatar
Axle/Gears: 3:42
Install the timing pointer. Use a piston stop to get to TDC, put a mark on the balancer where the pointer has its 0 mark. Turn the engine backwards and make another mark on the balancer at 0 again. Then make a mark in the middle of those two lines on the balancer. That is TDC. Then adjust the timing pointer accordingly to match that center line on the balancer. I mean what Sofakingdom said is correct also. It should be close enough that way too.
Old Dec 23, 2011 | 10:34 AM
All you have to do here, is find TDC by the most accurate means possible; then set the engine to that spot; then make the pointer point to the timing mark.
Your degree wheel method is fine: if your piston stop stopped the engine at 0° on the degree wheel going one way, then at 30° on the degree wheel when turned the other way, then TDC is at 15° on the degree wheel ... halfway in between, as ninetyone describes. Ignore the balancer for this part of the procedure. Set the engine to that spot on the degree wheel, and then make the pointer point at the mark on the balancer, wherever it happens to be. That's all there is to it.
If, in your pic, the engine is currently EXACTLY AT TDC as it would seem to be from your description of how you used the degree wheel to locate TDC, then you're ready to point the pointer at the mark and tighten it down for good. Although, it should be fairly evident, the marks on the tab agree with the damper's mark to within about 1°, which is unusually close. You hardly even need the adjustable tab at all ... today. Now, after a few hard runs have settled the spooge blob a little bit, who knows.
As Damon says, there's a spec for where the mark is "supposed" to be on the damper. But there's tolerance EVERYWHERE in that: the #1 rod journal might be a little off, the crank keyway might be off, the keyway in the balancer might be a little off, the blob of spooge between the damper's hub and its inertia ring might be .... a blob of spooge, and the inertia ring might be assembled to the hub a little off. That's ALOT of places where small errors can creep in. Which is of course why it's necessary to verify the mark/pointer alignment in the first place.
Old Dec 23, 2011 | 10:43 AM
Thanks for the info, guys! I left my timing marker alone and used ninetyone's method by putting tape marks on the balancer. It came to pretty much match the method I previously used. So, I think it's all good.
I agree with Sofa in that there are tolerance everywhere and, as a result, nothing is going to line up perfectly. Although it would be nice
I did notice my new balancer has the 0* number on it (along with other degree numbers) but then has another carved-line in it about 5 inches to the left. What is that line for?
Old Dec 23, 2011 | 10:53 AM
Iunno... a measurement of how many degrees it is away from TDC might offer a clue.
RazorN8
Jan 7, 2022 11:44 AM
midge54
Dec 27, 2019 04:14 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
Thirim
Aug 9, 2015 06:19 PM
