rusty fuel tank??? anybody experience??
Old Dec 23, 2011 | 12:59 PM
goliath88's Avatar
Car: 88 firebird convertible
Engine: 305 tbi v8
just curious, has anybody encountered a rusty fuel tank with their car?? if so, what were your symptoms that made you want to change it out..
Old Dec 23, 2011 | 02:18 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: rusty fuel tank??? anybody experience??
only way to tell for sure if you have rust in the tank is to LOOK in the tank.
Old Dec 23, 2011 | 03:26 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
I had the fuel tank out a few weeks ago in my '86 and had no issues with rust. It had very little debri in it, no rust, no rocks, no sediment, pretty clean actually. Except for the sock being a little discolored even that was clean.
Old Dec 23, 2011 | 04:16 PM
goliath88's Avatar
Engine: 305 tbi v8
my car was stored for 4 years (gulf war vet), and then again for 1 year.. ive dropped the tank and saw it when i cahnged the fuel pump, did the old drop-a-chain and shake routine to it to break up the corrosion and tar buildup.. ran ok for a bit but started clogging up my fuel filter every week. the reason im asking is because i wanted to see if anyone else had any mechanical problems to their car and figured out it was the gas tank..
Old Dec 23, 2011 | 04:19 PM
travis401's Avatar
Car: 91 Camaro RS
a good pump sock should prevent any rust flakes or debris from being sucked into the filter to begin with.
Glowsock
Jul 24, 2025 03:15 PM
mustangman65_79
Apr 14, 2017 05:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Winchester1094
Aug 18, 2015 10:23 AM
AkDrifted
Aug 17, 2015 07:45 PM
