fuel pumps
Old Dec 25, 2011 | 03:38 PM
cactusman92's Avatar
Car: 1991 Chevrolet Camaro Z/28 (Project
Engine: 5.0L 305
Transmission: 700R4 W/ B&M shift kit
fuel pumps
I have a 91 camaro z/28 its a 305 oem injectors, high flow exhaust, tbi spacer plate, and an oem fuel pump so now leads to the question i want to upgrade my fuel pump to a performance fuel pump and was wondering if it would be worth it or what all i would have to upgrade with that as well or if it would pose major issues like destroying my engine assuming thats all im putting in no other upgrades or mods. the stock one only cranks out about 13psi any information or opinions would be greatly accepted
Old Dec 25, 2011 | 03:57 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: fuel pumps
Once your injectors hit max duty cycle, and you can no longer maintain your desired Air Fuel Ratio (as monitored by a wideband O2 sensor) when you are at your maximum engine RPM at WOT, then it's time to upgrade the fuel pump,
- or if you are near this limit and plan on adding more fuel delivery for a power-adder such as a nitrous system,
- or if your pump fails,
then it's time to upgrade the fuel pump.
This would probably be best posted in the TBI section.
Old Dec 27, 2011 | 02:51 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: fuel pumps
with the limited mods you have on the vehicle so far, a fuel pump really won't make much of a performance difference. unless yours is dead or failing, you'd probably be better off spending money elsewhere before upgrading the fuel pump
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
